  3. Drill Legend Table error
  • Subscribers 166
  • Views 12935
KKSP
KKSP over 6 years ago
I have two different drill layer pairs:  "top to bottom" and "top to inner".  Everytime I create a drill table, the "top to bottom" texts and "top to inner" texts are layered on top of each other instead of being two separate table.  I am using the default-in.dlt file to create the table.
Any suggestions will greatly be appreciated.
  • steve
    steve over 6 years ago
    This is default behaviour the first time you make the charts. Once you place them use Edit - Move and in the Fine Pane enable Groups then left click one of them and it will move as a group, place this down where you want it. The next time you create drill charts the positions are remembered.
