  3. Continue in line width while routing automatically
  • Subscribers 166
  • Views 14936
Sulmaz
Sulmaz over 6 years ago
Hello guys,
I was trying to find out if Allegro can do this but without any success. I am  using version 16.6. I would like to know if Allegro can automatically continue in line width while router so I do not have to type line width every time. Example: I delete some Cline segments from line wide 12 mils. Then I delete some Cline segments from line with width 20 mils. Now I want to route the first line. But instead of typing the line width to Options window, I would like to click on the line and allegro automatically continue in the wide of this line. So back to example - if I would click on the line with width 12 mils allegro would continue routing with 12 mils line. Same for the 20 mils. Can this be set somewhere? It would ease my work significantly.
Thanks for any response.
  • Dale Peterson
    Dale Peterson over 6 years ago
    Just setup a few keyboard keys with your favorite trace widths. So then why you are routing a trace just hit your keys as you go.  Here's an example of key that i have setup in my ENV.  It assigns the "q" key up to change the line width to .2mm.
    funckey q      FORM mini acon_line_width .2
    Good luck!
  • Wild
    Wild over 6 years ago
    I have found that when in routing mode (Allegro 16.6)  if i set the Line Width (Options) to Constraint and I route from a Cline Seg then the route will continue at the same width.
    Hope this helps
  • CadAce2K
    CadAce2K over 6 years ago
    Hi Sulmaz. If I'm reading this correctly you're wanting the line width you're continuing to use the width it currently is. As you say: "I delete some 12 mils cline segments, and some 20mil segments" and you want to continue routing with the line width already routed. If so, you just leave the 'line width' option as 'default' (whatever your default is), and the Add Connect will use the line width already routed, and just continue on. If you don't change the 'default' line width, you can add to the routing with the line width already used.
    BTW - I set constraint (Physical) regions to do this automatically. Works much easier. And it's not too tricky to set up.
  • Sulmaz
    Thank you guys for the help. As I tested your solutions, CadAce2k sugestion is what I meant. For some reason I always entered the line width and never tried to continue without typing anything into that box. Thank you, that was exactly what I wanted to Allegro do.
    Dale: I have already setup bunch of keys for most used functions but I will also consider add some for most used widths.
    Wild: I usually not setting up constrains for the lines except of minimum width and spacing. Probably should do this beforehand.
  • CadAce2K
    CadAce2K over 6 years ago in reply to Sulmaz
    You always want to set up (as a minimum) your line widths and spacings. It stays with the design and when you re-use the design your settings are already default. I can't tell you how many times I've opened another designer's board and wondered how da hell did they determine line widths/spacings!!! (Note: Tweaking the settings implies you're no longer a novice user.)  :)  Glad we could help.
