  3. amplitude modulation
  • Views 14363
Isanuel
Isanuel over 6 years ago
I want to simulate amplitude modulation and at first that student understand the operation of AD633.
I have this message : warning (ornet-1119) : the part/device cannot be simulated. No pspice template found on U1 ; ignoring this parrt/device from simulated netlist - use place -> Pspice component ... -> search to place simulation ready part.
I'm a novice and I dont known how to do !
Sorry for my bad english Disappointed
The circuit :
  • oldmouldy
    oldmouldy over 6 years ago
    You have placed the AD633 part from the "PCB" libraries, <installation_path>\tools\Capture\Library, and not the AD633/AD part from the <installation_path>tools\Capture\Library\PSpice "PSpice" libraries, this will have the properties required for simulation attached and a model defined in the "master" nom.lib
  • Isanuel
    Isanuel over 6 years ago in reply to oldmouldy
    Thanks a lot!
    I just checked but I have not AD633/AD. I only have AD633 or AD633/SO, which are not doing the job.
    I have another solution, which enable me doing what I want: I use MULT but it is not a real component if I have well understood…
