  3. "snap pick to" function
  • Views 4379
masamasa
masamasa over 6 years ago
hello
whenever i try to select objcts, i need to choose either a via or a pin.
so i always use "snap pick to" on the right click menu.
i created a shortcut command using "funkey" on the env file.
i assigned "1" for snap pick to a via and "2" for snap pick to a pin.
funckey 1 "prepopup;pop dyn_option_select 'Snap pick to@:@Persistent snap@:@Via'"
funckey 2 "prepopup;pop dyn_option_select 'Snap pick to@:@Persistent snap@:@Pin'"
when i press key "1", i can snap pick to a via, but after pressing key "1", i can not snap pick to a pin by pressing key "2" even after i finish the command.
did i do something wrong?
  • redwire
    redwire over 6 years ago
    Try a non-persistent syntax and see if that works correctly:
    funckey 1 "prepopup;pop dyn_option_select 'Snap pick to@:@Via"
    funckey 2 "prepopup;pop dyn_option_select 'Snap pick to@:@Pin'"
  • masamasa
    masamasa over 6 years ago in reply to redwire
    thank you, redwire.
    it works now
    the ones you suggested work under persistent snap as well.
    thank you
