  3. Generating a back annotate file using File/Export logic...
  • Subscribers 163
  • Views 637
Generating a back annotate file using File/Export logic/netlist Other - Problems
Lennie
Lennie over 6 years ago
I have a pcb file that I swapped a number of functions(gates).
When I run File/Export logic/netlist Other on the pcb file that I swapped gates against the original pcb file I get errors in the log file as shown below. Any ideas what the error means or how to fix it ?
I even saved the updated pcb file and loaded the original netlist and get these errors.
Warning TF-13266 not matched in START database!
Warning TF-13265 not matched in START database!
ETC.
