  3. find filter control
  • Replies 7
  • Subscribers 166
  • Views 15061
find filter control
masamasa
masamasa over 6 years ago
hello
is there any way i can create a shurtcut key for turning on "All on" and "All off" on the Find Filter?
also i would like to be able to select "vias" only on the Find Filter by typing one shortcut key.
  • CadAce2K
    CadAce2K over 6 years ago
    The layer visibility has the easiest button clicks for turning "ALL ON"/ "ALL OFF". Pretty simple. You need to start experimenting with the tool and find out all the goodies.
    "Vias" - what's simpler that "all off" "vias on" in the find filter???
  • masamasa
    masamasa over 6 years ago in reply to CadAce2K
    thank you for your reply.
    what i want is to assign "all on" to one shortcut key.
    is it possible?
    i assigned a command like "via assign net" as funckey 2 "via assign net" on the env file so that i can simply type 2 to display the command.
  • steve
    steve over 6 years ago in reply to masamasa
    try typing scriptmode +e at the command line followed by a return then invoke the command you want, the command line will report back the actual command you used, in this example try funckey x QtSignal ColorVisibilityPane CVPGlobalVisOff clicked
  • DavidJHutchins
    DavidJHutchins over 6 years ago
    below is what I got to work in 16.6 using <Ctrl>Pgup and <Ctrl>Pgdn keys:
    funckey CPgup '(axlShell "setwindow form.find;FORM find all_on;setwindow pcb")'
    funckey CPgdown '(axlShell "setwindow form.find;FORM find all_off;setwindow pcb'
  • DavidJHutchins
    Opps - last entry was from an earlier trial, below is the final version:
    funckey CPgdown '(axlShell "setwindow form.find;FORM find all_off;setwindow pcb")'
