  3. place via array acting funny
  • Replies 10
  • Views 16916
TSCphil
TSCphil over 6 years ago
Any one else having trouble with place via array (boundry) since the latest 17.2 hotfix57?
I'm trying to place an array just inside the outline of a 2" circular board.
Appears that allegro is not seeing the "non-circular object settings" ( I want the array to be a specific distance inside the outline and a specific spacing).
No matter what I do, even with "non-circular" selected, it adheres to the circular setting (specific radius and specific angle).
Phil
  • TSCphil
    btw - I've done this many times over the last few years. Hasn't been a problem till now.
  • redwire
    redwire over 6 years ago
    Just to be clear.  Did you try with HF56?  I am on HF56 and it works fine.  Have not tried HF57.
  • TSCphil
    TSCphil over 6 years ago in reply to redwire
    yes, seems to have gone whacko since installing hotfix57.
  • TSCphil
    I also tried this on a coworkers computer who has also installed HF57. His seems to be stuck on the "circular settings". Just the opposite of what mine is doing.
    I think it sticks on whatever setting you have selected when you invoke the command.
  • redwire
    Ok, try one more thing in HF57 for me. ( I see something whacko in HF56 as well.)  Try this:  Place->Via Arrays->Boundary and then over in the options window in the section now called "Object-ring parameters", click on Circular, then non circular, then circular and my options window then correctly displays the parameters for circles and then it works.  I didn't see anything in the HF57 bug fix that touched this operation so I am thinking it's the same as what HF56 is doing.  The options window appears to now be out of sync with itself.  This is new since ~HF52?
