  3. Orcad Capture - How to change the colour of multiple text...
  • Subscribers 163
  • Views 8262
Orcad Capture - How to change the colour of multiple text based objects at the same time ?
excellon1
excellon1 over 7 years ago
Hi
How do I go about changing the colour of multiple selected items such as "Net Aliases", Notes, RefDez etc in Capture ?. I can only change the colour one entity at a time.
Basically what I was expecting is to Ctrl click each object then right click properties and change the colour. That does not seem to be an option ?
I am running the current version.
Thanks..
  • steve
    steve over 7 years ago +1
    Select the items you want and right click - Edit Properties. In the Property Editor, select the relevant tab then right click the property name (ie Color) and choose Edit, this allows you to set a color…
  • excellon1
    excellon1 over 7 years ago in reply to steve +1
    Hi Steve, There is no Right Click "Edit Properties" option when I select multiple items. For example I selected 3 net aliases "Net Names" so they are highlighted using ctrl+click. Choose right click and…
  • excellon1
    Thanks for the sanity check Steve. This thing is honestly not credible, hard to believe eh.
  • steve
    Select the items you want and right click - Edit Properties. In the Property Editor, select the relevant tab then right click the property name (ie Color) and choose Edit, this allows you to set a color for those object types. Repeat for the other tabs along the bottom). The other method (but this is more global) is to go to Options - Preferences, and set the Colors for the objects there.
  • excellon1
    Hi Steve, There is no Right Click "Edit Properties" option when I select multiple items. For example I selected 3 net aliases "Net Names" so they are highlighted using ctrl+click. Choose right click and the edit properties option is greyed out.
    I can change the net alias colour one at a time, I am trying to do more than one at a time.
    Here is a picture
    There is other high strangeness too. When I create symbols that contain lines, I cant select them all at one time and do a global change on the line style. While the lines are selected if I do a right click the edit properties option is also greyed out. Selecting one line at a time it is easy to change the style as it is too with net aliases etc.
    Maybe i'm missing something here ?
    Thanks..
  • steve
    steve over 7 years ago in reply to excellon1
    No, I misunderstood what you wanted. You can't do what you want. You can only use the Options - Preferences to set colors for all net aliases or all refdes. or do them individually
  • excellon1
