  3. License Error
  • Subscribers 166
  • Views 20175
License Error
Brunel
Brunel over 6 years ago
When I run the software I am getting the following error
Retrieval of 'Allegro PCB_Design Planner' license failed:
'ERROR (LMF-13018): License call failed for feature
Allegro PCB_Design Planner. The license server search path is
defined as <none> The FLEXnet error message is as follows,
FLEXnet ERROR(-18, 234, 0): License server system does not
support this feature.
Run 'lic error LMF-13018' for more information.'. Repot the
licenses in use log Via the menu item File-» Viewlog:
license_use.log
When I use the License Utility it is showing the correct port and server for the license, I have also checked the System Variable and this is also correct, btw I am running a silent install for this
Any Ideas?
  • oldmouldy
    oldmouldy over 6 years ago
    Allegro Design Planner is a specific product and has it's own license. And it looks like you don't have a license for that. You, more likely, want to be starting PCB Editor for the PCB tools. How the products were installed will have no bearing on what licenses are available from the license server.
    • Vote Up -1 Vote Down
