  3. Assign Voltage For Power and Ground Nets
  • Subscribers 167
  • Views 16761
mikkelhansen
mikkelhansen over 6 years ago
I am working with Capture CIS and this window appears when trying to save changes to my page. I cannot save the file without seeing this window. What does this window mean, and how will it affect my schematic/layout? Can I save my file without assigning these voltages?
  • Lock2002
    Lock2002 over 6 years ago
    I don't know why you keep seeing this window, but it will have zero effect on your layout. The only thing I've noticed is when a voltage is assigned the nets are displayed with a small X over each connection instead of the typical rats nest.
  • steve
    steve over 6 years ago
    Ok so this form is only shown if you have invoked the Constraint Manager mode (setting constraints at the front end) and usually appears the first time so you can setup your power nets and then any time if you make changes to any power nets or any pins that are type Power.
  • mikkelhansen
    mikkelhansen over 6 years ago in reply to Lock2002
    Thanks for your reply.
  • mikkelhansen
    mikkelhansen over 6 years ago in reply to steve
