  3. gerber file extensions
  • Subscribers 166
  • Views 16665
seacorper
seacorper over 6 years ago
what are the file extensions that I will be sending to a manufacture after my board design is complete?  I have to take an extra step and have files run through a "data scrubber program" after leaving my secure server.  This program will only work with ASCII based files.  I know there are (.art) files, are there any other type of files pcb manufactures need from OrCAD pcb design.
  • CadAce2K
    CadAce2K over 6 years ago
    1) Gerbers (normally .art or .pho or .gbr extension ; the extension doesn't matter, except to your preference). Can be supplied as a folder
    - All PCB layers, individual gerbers
    - Top/Bottom silkscreen
    - Top/Bottom soldermask
    - Drill file(s) - normally a .drl extension
    2) Your fabrication drawing - .pdf file works great (or you can submit as gerber too)
    3) Optional: ODB++ in case your fabricator can use that in lieu of gerbers (and saving NRE costs)
    4) Optional: An approved supplier stackup detail even if you have the details in your fabrication drawing.
  • masamasa
    masamasa over 6 years ago
    you should ask this question to your manufacturer first as to what kind of gerber format they need.
  • CadAce2K
    CadAce2K over 6 years ago in reply to masamasa
    FYI - I've not encountered a problem with Gerber 274X (either 2,5 or 3,5 format) yet with suppliers, onshore or offshore. I still prefer ODB++, but give gerbers also, just in case. BR
