  3. Regarding importing and eding of Eagle PCB boards to Allegro...
  • Replies 15
  • Subscribers 167
  • Views 19470
Regarding importing and eding of Eagle PCB boards to Allegro PCB Designer 17.2 linux version?
VijayKK
VijayKK over 6 years ago
Hi i have some of my eagle PCB layouts. And i want to shift it and edit it on my  allegro pcb designer linux version 17.2. But i am not able to find any option for doing this . Please help me out?
  • jc teyssier
    jc teyssier over 6 years ago in reply to VijayKK
    As Steve says: obtain and install the latest hotfix for 17.2 ( Seems you are using 17.2 with an old hotfix (S017)
    Latest one is S058 (now); i think Steve have a keyboard with "8" and "9" to close Slight smile
  • CadAce2K
    CadAce2K over 6 years ago in reply to Julie517
    Hi Julie517. Please don't post spam to this site, or we will have admin remove your account. This goes against the blog guidelines, and will lead to your removal. Thank you.
  • VijayKK
    VijayKK over 6 years ago in reply to VijayKK
    As suggested i have updated to S058, but still i am not able to get the Eagle translator.
  • VijayKK
    VijayKK over 6 years ago in reply to jc teyssier
    I have dowloaded the latest versio S058
  • steve
    steve over 6 years ago in reply to VijayKK
    Ok can you try typing ns_eagle2allegro at the command line in Allegro followed by a return to see if the importer starts? If it doesn;t then it may only be available in the Windows version. If it does then go to Setup - User Preferences - Paths - Editor and look for menupath, chek the value is pointing to C:\Cadence\SPB_17.2\share\pcb\text\cuimenus as the top entry then restart Allegro and see if that shows the menu.
