  3. Orcad Capture 17.2 TCL & Symbol creation.
  • Subscribers 162
  • Views 4264
excellon1
excellon1 over 6 years ago
Hi, I was wondering is it possible to use TCL in orcad capture when creating symbols.
Specifically what I want to accomplish is the addition of attributes to symbols by automating the process.
When I create a symbol I like to pre-load the symbol with attributes so that I can generate a meaningful BOM and or make a schematic more legible. For example on my schematics I include the PCB Footprint value on each symbol so a engineer can see at a glance what PCB Footprint is assigned to that particular symbol. I also have additional attributes that would be geared to the bom such as P/N, MFR PN etc but these typically remain hidden.
Thus far doing this has been a highly manual operation that I am trying to automate and was thinking TCL may just be the answer.
If anyone has any insight on this it would be very helpful. I had looked over the TCL Documentation but it seemed more geared to the schematic than physically creating symbols.
Thanks.
  • Alok Tripathi
    Alok Tripathi over 6 years ago
    Yes. You can use Tcl to create symbol or add additional properties. Here is a sample script to add a new property
    You can add new property on symbol using following tcl commands:-
    # [Assuming you have object of DboLibPart  ($lPart) ]
    set mStatus [DboState]
    set lPropName [DboTclHelper_sMakeCString {Description}]
    set pLocation [DboTclHelper_sMakeCPoint 40 60]
    set pFont [DboTclHelper_sMakeLOGFONT {Description} 8 0 0 0 400 0 0 0 0 7 0 1 16]
    set mProp [$lPart NewDisplayProp $mStatus $lPropName $pLocation 0 $pFont 48]
    $mProp SetHorizontalTextJustification 0
    There is no direct API through which you can move the Display property but you can change the location of Display Property using following tcl commands:-
    set lPropName [DboTclHelper_sMakeCString {Part Reference}]
    set lDisplayProp [$lPart GetDisplayProp $lPropName $mStatus]
    $lDisplayProp SetLocation [DboTclHelper_sMakeCPoint 100 100]
  • excellon1
    excellon1 over 6 years ago in reply to Alok Tripathi
    Hi alokt thanks for helping, I will give it a go.
    All the best.
