  3. Orcad capture 16.5 - warning, part name during netlist generation...
  • Views 2980
shavai
shavai over 6 years ago
Hi, am using orcad capture 16.5.
While generating the netlist, I came across the warning which shows like below
WARNING(ORCAP-36006): Part Name "CAPACITOR POL_CAPAE660X800M_47UF" is renamed to "CAPACITOR POL_CAPAE660X800M_47U".
1. How do I solve it?
2. Can it be ignored?
Please help.
  • steve
    steve over 6 years ago +1
    Its only a warning because by default the netlist device name limit is set to 31 characters. You can happily ignore these or if you don't go to Tools - Create Netlist then click on the Setup button and…
  • steve
    Its only a warning because by default the netlist device name limit is set to 31 characters. You can happily ignore these or if you don't go to Tools - Create Netlist then click on the Setup button and change the Device/Net/Pin/Name Char limit to 255. Remember you do this do the same in PCB Editor under Setup - Design Parameters - Design tab and set the long name size to the same
  • shavai
    shavai over 6 years ago in reply to steve
    Thanks. It worked.
