  3. net assignment question
  • Views 14699
masamasa
masamasa over 6 years ago
hello
how can i assign a net as a ground or power?
based on the artical below, i should identify the power and ground nets in order to maximize the performance but i do not know how.
https://community.cadence.com/cadence_blogs_8/b/pkg/posts/how-to-maximize-performance-when-your-package-layout-gets-complicated
i assume i need to assign some nets as ground or power in the constraint manager.
currently all nets on the netlist are assigned as a signal net so any command takes a long time to execute.
  • steve
    steve over 6 years ago
    In Constraint Manager go to Properties - Net Properties - General and add a Voltage value for the Power and GND nets. They will then display differently in the design (so not point to point but show a square with a cross in the middle on each pin).
  • masamasa
    masamasa over 6 years ago in reply to steve
    thank you steve
    i was able to set up the ground and power nets and saw a cross in the middle on each pin.
    but i do not see any significant performance difference on each command yet.
    you always help me a lot.
    anyway thank you again.
  • masamasa
    masamasa over 6 years ago in reply to masamasa
    one more question,
    i got this message after i run the performance advisor on dbdoctor.
    * PLANE_FL3 net has VOLTAGE property, but the ratsnest schedule is is NOT  "POWER_AND_GROUND".
    how can i set the nets with the voltage property i specified as "power and ground" on the ratsnest schedule?
  • steve
    steve over 6 years ago in reply to masamasa
    Try Edit - Properties on the net (Find pane) then choose Ratsnest_Schedule and set Power and Ground. Not convinced this will give you a huge saving either.
  • masamasa
    thank you steve
    i was able to setup the ratsnest schedule.
