  3. Error: Table name not found in dbc (CIP)
  • Views 14577
jatins
jatins over 6 years ago
Hi
The above error is still showing up even when i have setup dbc file again.
Also, some of the parts in Part Manager window do not have any part number assigned to them.
  • steve
    steve over 6 years ago
    CIP comes with default configuration files. These are stored in C:\Cadence\CIP-E\Configuration_Files folder. Try one of these to start with, maybe:- CIP-E V6.9 CIS DB.DBC and see if that helps, you can then make any changes you want after its working.
  • RFinley
    RFinley over 6 years ago in reply to steve
     At some point, the installer started sharing the config file directory on the server to the public.
    >Network >(CIP-E server host) > Configuration Files.
