  3. Update net names and net groups in an existing design
  • Views 15770
FWang
FWang over 6 years ago
Hi Cadence,
I need to rename some nets in my design and they are part of netgroups I created previously. However it seems renaming netgroup instance name is not that easy, since there is no rename button can be used. When I tried to create new net groups and remove the old ones, I got the error ORCAP-1828:
I am pretty sure that this netgroup has been removed from my hierarchical design, but I can still find it in the design cache, Netgroup Definitions, cleanup cache didn't work.
Any comments helpful will be appreciated, my goal is to keep the previous PCB design, I just want to update the net names.
Thanks!
  • oldmouldy
    oldmouldy over 6 years ago
    If the Netgroup has members listed in the UI and you cannot delete, try Edit>Browse>Nets with the DSN file selected in the Project Manager. This will list all of the Nets in the design. If the Netgroup members are in the list, double-click on the entry to be taken to the schematic page containing the Net. That may help to identify the remaining Netgroup segments.
