  3. Detailed Segment XTlk report contains intra Diff Pair C...
  • Views 12592
Detailed Segment XTlk report contains intra Diff Pair Coupling
archive over 17 years ago
Does anyone know if there's a command, setup or switch whereby when you run a detailed segment crosstalk report  you can omit  coupling that is reported within a diff pair?  Ie., what I'm seeing reported is both XTlk from local unrelated agressors (which I want) as well as from the P to the N and vice verca within the same diff pair.
In 16.0 GXL I know there's a box to check if you want intra trace coupling reported, but I do
not have that checked.  The diff pairs are defined both in the layout structure and as IBIS models
as diff pairs, so the system should recognize (and in fact does via SigXP) that they are diff pairs.
Hopefully it's something I've fat fingered.
Thx
Nick
Originally posted in cdnusers.org by njk
    We use a script to parse the xtalk reports to weed out the P to N coupling.
    Originally posted in cdnusers.org by Kalevi2
