  3. Issue in creating the variant BOMs by customizing the value...
  • Views 13331
Issue in creating the variant BOMs by customizing the value field
Micheal schenk
Micheal schenk over 6 years ago
I am using OrCAD Capture CIS 17.2 059. I am facing a issue in customizing variant BOM.
I have a design where the component holds two different values say for example inductor L1 has 12.8mH and another case 1.8uH and for the same I want create a BOM variants V1 and V2.
The issue is I want to create a BOM v1 which has L1 value 12.8mH and V2 having 1.8uH. I don't want to do any manipulation to design or database. Is there any method to do so ??
  • oldmouldy
    oldmouldy over 6 years ago
    You control the BOM Variants through the Part manager. All the parts start in a "Common" Group, create some Groups, and Subgroups, to handle the parts that you want to change between the Variants and then create the BOM Variants from a combination of the Common and Sub Groups. See the documentation on "Working with Database Parts"
