  3. conn model 4 multi-board simulation
  • Subscribers 163
  • Views 12765
archive over 18 years ago
If a board has a large (120) pin connector and the vendor has a multiline (fractional) version of the model (say 20 pins for middle of the connector) does it make sense to have them generate a complete 120 pin connector model and then in the layout assign that model to the entire connector?
Or should we work with a section of the mode and move it around depending on the signals we want to model (SE or Diff)?
When we use multiboard design links and we use a Mated connector model.  do we assign the model only to 2 of 3 boards (once per conn) or do I assign the same model to board1board2
board1-[mated conn] [mated conn]--board2--[matec conn]  [mated conn]--board3
side view is:
board1                     board3
[conn]-motherboard(board2)-[conn]
so my signal goes from board1 to board3 via motherboard.
Originally posted in cdnusers.org by salva004
