  3. Laser Via - Buried Via
  • Subscribers 167
  • Views 1909
aemeehan
aemeehan over 5 years ago
One of our layouts slipped through with a laser via on top of a buried via (fab house caught it). I don't understand why the system didn't flag it. We had BB via stagger set at 0.3837mm, and via-to-via spacing set at 0.1mm. I've been experimenting with the pad-pad connect settings, but unless I set it at 'All Allowed', I get tons of non-errors. It seems like it should be a simple setting issue, but what settings do I need that to edit to get it to flag a laser via on top of buried via? Thanks for any guidance.
  • aemeehan
    Sorry, meant to say "what setting do I need to edit to make the system flag a laser via on top of a buried via?" Thanks.
  • masamasa
    masamasa over 5 years ago
    i assume you want to find the stacked via locations.
    this skill code might help you.
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O0V000006Ak17UAC&pageName=ArticleContent
  • redwire
    redwire over 5 years ago
    I had raised this issue on the forum around 9-12 months ago and never got a real answer.  I was using 16.6 at the time and if the laser via was exactly on the same coordinate as the mechanical via it did not trigger a DRC no matter what setting I did.  If it was off just by a small amount it would trigger so I suspect the software allows this since some fabricators are ok with zero offset.
    All that said, the way I found was to run a via location extract and parse it in Excel for like coordinates...sigh.   Which version and license level do you run?  It might be a higher license level that can find this...
  • aemeehan
    aemeehan over 5 years ago in reply to redwire
    We're using 17.2 along with the high-speed/miniaturization option. I'm hoping there's a way to flag it with a DRC rather than any other option, but sounds like there may not be a way to do that. Thanks for responding redwire and masamasa.
  • redwire
    redwire over 5 years ago in reply to aemeehan
    Have you asked your VAR?  Sometimes their apps guys know these tricks which escape even us power users.  I would ask that if you do solve it, please post the solution for the rest of us.  Happy hunting.
