  3. select primary net on the SigExp
  • Subscribers 163
  • Views 13291
archive over 17 years ago
Hello, When I simulate a diff pair in the SigExp, with multi point net (driver with more then 1 receiver) I get a window "select primary net". What does this mean? If I select on receiver the simulation is behaving different from a different receiver? My case is a clock source that is driving 2 memories and a clock in. I want to check on all receivers at the same time. thank you, D.
Originally posted in cdnusers.org by darmoni
    maybe you can simulate on one receiver, then on the otherone, but after the first simulation: dont close the sigwave window! this way 2 simulation results will be in the same graph. thats how i simulate buses too...
    Originally posted in cdnusers.org by buenos
