  3. Orcad 16.6: problem with "Delete Unconnected Copper" co...
  • Views 1443
Orcad 16.6: problem with "Delete Unconnected Copper" command
Leotordo
Leotordo over 6 years ago
 when I lunch the command it works properly.
Here an example
https://ibb.co/kc0FPqV
If I stretch a trace the Dynamic Shape will be update properly (around the trace), but the void of previous unconnected copper remain.
https://ibb.co/c2WHNbc
Isi it possible to update voids?
Stefano
  • steve
    steve over 6 years ago
    Try Shape - Manual Isolation/Cavity - Delete, set the Find pane to just voids/cavities then window the area to remove the old voids and this should resolve your issue.
  • Leotordo
    Leotordo over 6 years ago in reply to steve
    it works!
    Sorry but I'm newbie in Cadence systems and I usually work on 17.2, but this jobs must be done on 16.6
    thank you very much Steve
    bye
    Stefano
