  3. Assign net class in object property
  • Views 15942
Leotordo
Leotordo over 6 years ago
 I would like to set net classes into schematic.
The only way I know is setting a common BUS_NAME then I make a class into BRD file where the only memeber is the bus BUS_NAME
Is there another way?
Stefano
  • steve
    steve over 6 years ago
    Yes add a NET_PHYSICAL_TYPE or NET_SPACING_TYPE property with the name you want to call the Netclass to the nets you want. Since 17.2 S048 (I think) you can also launch Constraint Manager from OrCAD Capture and do it there as well.
  • Leotordo
    Leotordo over 6 years ago in reply to steve
    thank you Steve. I'll try tomorrow
    bye
    Stefano
