  3. Ratsnest during move has changed? 17.2 HF60
  • Subscribers 166
  • Views 12400
redwire
redwire over 5 years ago
I'm seeing a major change in ratsnesting during move (ripup = ON) that was not present in 16.6.  In 16.6 if I move a specific component that is routed, when moving that part with ripup on, it properly rips up the routes and ratsnests all of the pins during the move.  In 17.2 HF60 the same board & part does not have the same ratsnest behavior - it will not rat all of the nets are connected to the part.  It appears that any nets connected to the part that have multiple pins in the net will not rat those  pins during the same move condition.  What changed?  How do I change it back?
  • CadAce2K
    CadAce2K over 5 years ago
    I believe Cadence has called that "an enhancement".  :) "If you want to post a problem in English; Press 1 now." HAHAHAHAHAHAHAHAHA
