  3. What creates Device Type name?
  • Views 13810
ToddR
ToddR over 5 years ago
I am trying to bring in a module to my design but none of the seed circuit components match the design components; even though they are the same p/n.
The reason this is happening I believe is the Device Type names are different. i.e.
The module properties show this for this resistor -  Device Type: RES-XX-XXX-XXLF,0,0%,1/10W,11_B
The design that I am trying to bring the module into shows this  - Device Type: RES-XX-XXX-XXLF,0,0%,1/10W,11_0603,ACTIVE-11_0603
(I exed out the actual p/n in these examples).
Why is everything after 1/10W different? What controls this setting?
I have Long Name Size set a 255 characters in both designs but the module may have originally been created with something less.
  • ToddR
    I was able to fix this issue. I deleted everything in the packaged folder. Ran Design Sync again and the longer Device Type names appeared in Allegro.
