  3. Failure of Using Altium Schematic Translator in Cadence...
  • Subscribers 166
  • Views 13351
Failure of Using Altium Schematic Translator in Cadence 17.2
Luella
Luella over 5 years ago
Hello!
I tried to convert Altium Designer schematic into Cadence Capture CIS. I followed the help document step by step, but it failed when I clicked the Translate button like the picture below. The file was converted to ASCII file. Is that a version problem or something wrong with the installation and license?
  • steve
    steve over 5 years ago
    Check to make sure you are running the latest version (Help - About should report 17.2-2016 S060). If it's not that get the latest version from http://support.cadence.com and try again.
