  3. Non functional pads
  • Subscribers 166
  • Views 14316
Non functional pads
wgr2010
wgr2010 over 5 years ago
How do you remove non functional pads from inner layers inside the layout?
  • oldmouldy
    oldmouldy over 5 years ago
    Setup>Cross-section, expand the Physical settings, check the boxes for the layers that you want to remove the unused pads from, select the Unused Pads Suppression tab and enable Dynamic Unused Pads Suppression, OK the cross-section and go to Constraint Manager and Analyze>Analysis Mode, Spacing, enable all of the Hole checks, otherwise traces through holes will be permitted since the Hole will be the only remaining DRC object when Pads are suppressed.
  • wgr2010
    wgr2010 over 5 years ago in reply to oldmouldy
    Thank you.
