  3. Display point to point rat nest for voltage nets
  • Views 15607
Jeff Underwood
Jeff Underwood over 6 years ago
My EE's have defined a lot of logical DC net voltages on our boards. Even though I don't use 'true' power planes, the guides for these nets appear as a square with an 'X' in the center of said square. Some of the many voltage nets will be connected on inner layers using areafills. However, a number of voltage nets will be routed as traces. How can I turn on the guides for those nets WITHOUT removing the assigned voltage on those nets?
  • RFinley
    RFinley over 6 years ago
    I would be surprised if this wasn't part of exporting and importing constraints from CM.
  • CadAce2K
    CadAce2K over 6 years ago
    Me do: Create a 'user defined' property for your voltages. Edit the nets and reset your VOLTAGE property to your new property. Then delete the VOLTAGE to get the ratsnest to appear. I don't know of another way around this, sorry.
  • mcatramb91
    mcatramb91 over 6 years ago
    Hi Jeff,
    Adding the Net Property "RATSNEST_SCHEDULE" to the Voltage net with a value of "MIN_TREE" will replace the power unroute with a traditional unroute.
    Hope this helps,
    Mike Catrambone
  • Jeff Underwood
    Jeff Underwood over 6 years ago in reply to mcatramb91
    Awesome Mike! I looked for hours over the course of two days before I broke down and admitted defeat. This worked like a charm.... Cheers.....
