  3. OrCAD Capture: Edit Multiple Pins
  • Subscribers 168
  • Views 17906
EASiA
EASiA over 5 years ago
When you are making a schematic symbol, is there a way to edit multiple pins to change their properties? For example, say I have 25 pins that have a shape of line but I want to change them all to short or zero length. I have only been able to only select one at a time to change them individually. It takes a while to change multiple pins that way. In other programs like EAGLE and Altium, they have the ability to make many quick changes. EAGLE can allow you to select a change tool and you can just click on the ones you want changed and then they change and Altium allows you to select as many objects that are the same and you can change them all with a simple selection to the new type. Does OrCAD have anything like this?
  • excellon1
    excellon1 over 5 years ago
    Hi this is not possible to do on pins. It has always been that way.
    All the best
  • redwire
    redwire over 5 years ago
    Which version of the tool?  Assuming you're in 17.2 it's as follows.
    In symbol library, open the part
    Either window select or ctrl-click to add pins to the select list
    Then SHIFT-H or right mouse EDIT PINS
    Only the selected pins will show up
    Set the pin type of the first pin
    Then drag the corner square on that pin down (like in Excel) to copy the type to the other pins
    Hope that works ok
    Yes, it's way more tedious than it used to be.  Not sure why this clunky style edit was added in recently.  It was much easier in the past. Disappointed
  • steve
    steve over 5 years ago
    Try the Edit Pins button....
  • EASiA
    EASiA over 5 years ago in reply to redwire
    This is basically what I was looking for. Thank you very much!!! Smiley
  • EASiA
    Thank you for all that replied. I had looked at edit pins before but it did not register with me that they could be edited that way. I probably thought all of that was more or less a report of what the pins were and not a source for editing. Redwire's specific instructions helped a bunch.
