  3. "Device File" error message showing up with HotFix60 in...
  • Subscribers 163
  • Views 2564
"Device File" error message showing up with HotFix60 installed
CadAce2K
CadAce2K over 6 years ago
Importing a newly created netlist from CIS, I'm now getting these 'old' DEVICE FILE messages:
Note: MFG_PN property definition created
#1   ERROR(SPMHNI-176): Device library error detected.
ERROR(SPMHNI-189): Problems with the name of device 'TESTPOINT5_0.125" DIA X 0.320"_1': 'Name is too long.'.
Note: PACKAGE property definition created
ERROR(SPMHNI-170): Device 'TESTPOINT5_0.125" DIA X 0.320"_' has library errors. Unable to transfer to Allegro.
#2   ERROR(SPMHNI-176): Device library error detected.
ERROR(SPMHNI-189): Problems with the name of device 'TESTPOINT5_0.125 DIA X 0.320 L_1': 'Name is too long.'.
ERROR(SPMHNI-170): Device 'TESTPOINT5_0.125 DIA X 0.320 L_' has library errors. Unable to transfer to Allegro.
I'm not aware of specifying the DEVICE information any longer, but this is now raising its UGLY HEAD.
Any help is appreciated.
  • RFinley
    RFinley over 6 years ago
    In case this is easy, from:  https://community.cadence.com/cadence_technology_forums/f/pcb-design/17431/netlist-importing-problem-in-orcad-pcb-editor-16-3
    Steve - "Under setup - design parameters Design Tab there is a long name size. The default is 31. I would set this to 255 (Max). Then try and import your netlist again....."
    (setup dialog in Capture CIS for "Create Netlist")
  • CadAce2K
    CadAce2K over 6 years ago in reply to RFinley
    Yep. That's the legendary fix. But for some odd reason it's not working on this database (CIS vs Allegro). I haven't seen the 'device' error in ages, but now it's happening on this 'old' design. I'm thinking it's got something to do with this 'old' CIS schematic and I need to refresh the components. I'm just not sure why allegro is complaining about the 'device' information. Thx.
  • CadAce2K
    As I suspected – there are 2!!!! Settings.
    • Global – in the user’s setting (env)
    • In each database – under Setup/Design Parameters/Design:
    Problem solved.  L
