  3. Quoted Identifiers not working with PostgreSQL ODBC
  • Views 13176
KevinL00
KevinL00 over 6 years ago
Attempting to use PostgreSQL with OrCAD CIS. Connection to the database is fine.
The issue occurs when attempt to view data when a table column has uppercase or special characters. Looking at the database logs, it appears that the column names are not wrapped in quotation marks in the SELECT query. Any way to address that? Is this an OrCAD issue or a driver issue?
I have set the "Parse Statements" setting on, but no results.
Environment:
 - PostgreSQL ODBC driver is 12.0.0, 32-bit. I am able to connect to server without issue via driver test.
 - We're running OrCAD Capture CIS 16.6-S062 (v16.6-112FF). Yeah it's a bit old....
 - Windows 10 Pro, 10.01.18362 Build 18362
