  3. SMD pin to SMD pin DRC errors when adding teardrops
  • Replies 17
  • Subscribers 166
  • Views 21018
Fredda
Fredda over 6 years ago
When adding teardrops to SMD pads it seems like they become a part of the pad. This leads to SMD pin to SMD pin spacing DRC errors since the pads have suddenly increased in size. Is there a way to avoid this?
  • CadAce2K
    CadAce2K over 6 years ago
    Maybe it's just me, but... I'll ask anyways. Why do you 'teardrop' your SMD pads? Over 30 years in the industry I've NEVER added teardrops to my SMD pins. Or any pins for that matter. Actually I've NEVER added teardrops to my vias either. I do have a note on the fabrication drawing that allows the fabricators to add them in highly-conjested (extra small traces/spaces) areas, but can't say any fabricator has. In my experience, the teardropping thingie comes from PADS, since it was so easy to add in PADS, but NEVER have I done it personally.
    BTW - I've worked for a good number of companies too, and have never been asked to add them.
    Just curious. Good day.
  • Fredda
    Fredda over 6 years ago in reply to CadAce2K
    I get the impression that the group advocating teardrops is as big as the one that doesn't. When the latter group is double the size of the former I will stop using them!
  • Fredda
    Fredda over 6 years ago in reply to Fredda
    In any case, I still wan't to figure out how to avoid a teardrop becoming a part of the pad during DRC.
  • steve
    steve over 6 years ago in reply to Fredda
    They do not create DRCs for me. Can you post a design or Picture so we can see what's going on?
  • Fredda
    Fredda over 6 years ago in reply to steve
    No DRC errors without teardrops:
    DRC errors with teardrops:
  • steve
    So in the Parameters for this is an Allow DRC box. Make sure that is unchecked BEFORE you run the command - see if that helps
  • steve
  • Fredda
    I've tried that, but the result is simply no teardrops at all with the following message:
    Enter selection point
    last pick: 6.5290 60.8977
    *WARNING: Can't create fillet at pad (6.4850 61.3400) on subclass TOP.
    Computed fillet point lies inside pad boundary; required to be outside.
  • steve
    So try adjusting the parameters to smaller values to get the fillets added. The Allow DRC;s chekced is why you are getting DRC's.
  • jc teyssier
    jc teyssier over 6 years ago in reply to Fredda
    Pin to pin is set to 0.4mm: too large!. Does U140 have 0.4mm between pins? Seems not. Why so large value? Teradrops becomes part of pins so the behavior is OK
