  3. regular pad flash and odb++ output
  • Views 15573
FormerMember
FormerMember over 6 years ago
We flash a 5 mil pad on the top and bottom layers for a non-plated hole.
A larger pad is there in Allegro 17.2 to keep copper away from the hole.
When we gerber out, the large pad is replaced with the 5 mil pad that gets drilled away.
We cannot get ODB++ out inside Allegro to make this substitution.
Is anyone doing some thing similar ?
Les
  • CadAce2K
    CadAce2K over 6 years ago
    Hi Les,
    This is the 'old' way of doing what you want. What I do is have the 5mil pad, but in the padstack set the 'Keep Out' to be the size you want the copper to be pulled back. You don't need to set a 'large' pad for keepaway any longer.  FYI - I don't set any "thermal pad" or "anti pad" definitions either since I don't use negative planes.
  • FormerMember
    FormerMember over 6 years ago in reply to CadAce2K
    Thank you.
    I guess we need to update are NPTH padstacks ....
    Les
  • eDave
    eDave over 6 years ago in reply to FormerMember
    Why not use the hole-to spacing constraint?
  • FormerMember
    FormerMember over 6 years ago in reply to eDave
    Dave
    I guess in the case of a NPTH we can since Allegro does not DRC to the actual Drill tool size yet ?
  • CadAce2K
    CadAce2K over 6 years ago in reply to FormerMember
    Hi. The reason I do it in the padstack (in the central library) is because it's 'global'. If you set it in the hole-to-spacing constraint, that's 'local' to each database. Too many chances for it to get overlooked if you're working with numerous designers. I go so far as to double-check stuff like mounting holes and make sure they're accounted for. Mechanical goodies can come back to haunt you. Good day.
