  3. PCI Express SI
  • Subscribers 161
  • Views 14252
PCI Express SI
archive over 18 years ago
Dear All,
             I want to perform SI work for PCI Express using x1 channel.
but don't know what shall i use as a standard agaist which i can do this work.
also what i need to check in SI for PCI eXPRESS, shall i check crosstalk, reflections also
shall i use datasheet and PCI Express base specification 1.1 only as  a standard...?
pls guide me on as i am doing this for the first.
thanks in advanced
M kumar.
Originally posted in cdnusers.org by manojkumar5745
    PCI-e standards require 100 ohm differential. Each trace pair must match with +/-5mil. As far as the specification, always use the latest, which is 2.0.
    Good luck,
    -o miguelino
    Originally posted in cdnusers.org by oscar@oqo.com
