  3. Regarding deleting X-Net property added for a signal in...
  • Views 6881
Regarding deleting X-Net property added for a signal in PCB board file
FormerMember
FormerMember over 5 years ago
Iam using 17.2version Venture pcb design tool. I need to delete an X-Net property which had been added for a particular net. Can you guide me on fixing this issue.
  • steve
    steve over 5 years ago
    Use Edit - Properties (set the Find Pane - Comps) and select the discrete part that the xnet is part of and add a no_xnet_connection property with a value of True to that part. Once applied the xnet will be gone. This property can also be applied at schematic level.
