  3. How to solve the problem INFO(ORCAP-2242): Checking Incorrect...
  • Subscribers 166
  • Views 5137
How to solve the problem INFO(ORCAP-2242): Checking Incorrect Pin Group Assignment
Jejiji
Jejiji over 5 years ago
Report for Invalid References
Report for Duplicate References
Checking Entire Design: PCB_DESIGN
Checking Power Pin Visibility
Checking Normal Convert View Sync
INFO(ORCAP-36105): Checking Missing Pin Numbers
Checking Device with Zero pins
INFO(ORCAP-36101): Checking Missing PCB Footprint Property
Checking Name Property for Hierarchical Instances
INFO(ORCAP-2211): Check High Speed Properties Syntax
INFO(ORCAP-2212): Check Power Ground Mismatch
Reporting Unused Refdes in multiple part packages
How to solve the problem?
Help me pls
  • excellon1
    excellon1 over 5 years ago
    Verify that your schematic symbol has the same number of pins as the actual footprint. Verify on your symbol that the pins have the correct swap properties assigned if the pins on a symbol are defined as swappable.
    Thanks.
  • Jejiji
    Jejiji over 5 years ago in reply to excellon1
    It is not show preview of component.
  • Jejiji
    Jejiji over 5 years ago in reply to Jejiji
    Could you solve this problem?
