  3. Locating drill hole
  • Views 14635
Locating drill hole
jatins
jatins over 6 years ago
Hi
In my customize drill table window, it is showing that there are 2 drill holes of 0.2mm size but i cannot locate these holes on my board.
Also the find window is not helping in finding these. As far as i could remember i have not used them. How can i find these holes on
my board?
  • KeithP
    KeithP over 6 years ago +2
    In the drill customisation form right click the number under the # column that you are interested in. This will list the padstacks used in the command window. Then use the find by query to find the…
  • KeithP
    Then use the find by query to find the relevant Vias or Pins Padstack Name. The Matching Objects part of the Query form is clickable which makes them easy to view.
    Alternatively, is the drill customisation form change the size of the drill symbol to something large and they should be visibly obvious.
    • Vote Up +2 Vote Down
  • avant
    avant over 6 years ago
    Try purging all unused padstacks under tools/modify/padstacks
