  3. Why flash symbols in padstack?
  • Views 16921
Sagetech
Sagetech over 6 years ago
Need to make some changes to a board I didn't do. Why would you use a flash symbol in a thru hole padstack?
What does flash DIRECT mean?
Tom
  • oldmouldy
    oldmouldy over 6 years ago
    The Padstack is using a Flash Symbol named Direct on inner layers (files direct.dra and direct.fsm need to be in the library path for this to work) The Thermal Pad and Anti-Pad are relevant if the cross-section uses Negative Artwork. Since relatively few organisations use Negative Artwork, the Thermal and Anti-Pad definitions could probably be removed, unless you are in of those organisations that still use Negative Artwork.
  • CadAce2K
    CadAce2K over 6 years ago in reply to oldmouldy
    Very true OldMouldy! Very true. Just more confusing to newbies. I can't tell you how many times I've turned those 2 off. I only use Regular Pad and Keepout. If I need to create odd-shaped pads (special chamfer pads for instance), I'll add them as "Shape Symbols" shown in the picture above. Good day.
  • Sagetech
    Ok, so I'm not going crazy - this time! I thought it was odd to do it this way also.
    My problem is that since I don't have the flash symbol, the gerbers won't generate. I need to go through the padstacks and fix the flash references then it will generate without error. Luckily this is a small board.
    This was an inherited design, not my doing. The only time I do anything like this is with a shape symbol and never a flash.
    Tom
  • UlfK
    UlfK over 6 years ago in reply to oldmouldy
    Question: Is there a way to batch-remove flash definitions in a padstack library once the decision not to use negative artwork has been made?
  • CadAce2K
    CadAce2K over 6 years ago in reply to Sagetech
    I'm curious. If you run 'dump_libraries' on the existing board file, will it output the flash symbols from the padstacks? I'm not sure if I've tried that in the past. Good day.
