  3. Report of Dynamic Shape Instance Parameters
  • Replies 8
  • Subscribers 166
  • Views 17057
Geras
Geras over 6 years ago
I have a board with hundreds of dynamic shapes where some of the shapes have instance parameters set that differ from the global parameter.  How can i get a report of every dynamic shape and what it's dynamic shape parameters are?  Or any other method that will tell me what shapes don't follow the global rules?
  • excellon1
    excellon1 over 6 years ago
    Hi, it is fairly painless to do this. Go to reports and choose "Shape Report"
    This type of report will list all the particulars of the shapes on your board including any properties that override the global parameters.
    Here is an example of the report. On the board there are two shapes. One of the shape has an oversized Thru Pin value of 25. (The report can get long, it may be able to parse it in something like Excel etc )
    Global Settings (First the actual global settings are reported ) --------------- Shape fill ---------- Dynamic fill Smooth Xhatch style Horizontal Vertical Fill Xhatch cells Off First Hatch Set --------------- Line width 5.00 Spacing 5.00 Angle 0.000 Second Hatch Set ---------------- Line width 5.00 Spacing 5.00 Angle 90.000 Origin (-500.00 100.00) Border width 5.00 Void Controls ------------- Artwork Format Raster Min Aperture for Gap width 4.00 Trim Control Round Suppression area 0.000625 (sq in) Pin Void Style Individually Snap voids to hatch grid Off Clearances ---------- Thru pin DRC 0.00 SMD pin DRC 0.00 Via DRC 0.00 Line/cline DRC 0.00 Text DRC 0.00 Shape/rect DRC 0.00 Thermal relief connects ----------------------- Thru pin Orthogonal Contact style min[2] max[4] SMD pin Orthogonal Contact style min[2] max[4] Via Full contact Contact style min[2] max[4] Using thermal width oversize of 0.00
    Shape Settings (One Shape in the design )
     Net name                                 dummy net
     Class                                    ETCH
     Subclass                                 TOP
     Extents                                  (3900.00 700.00)  (4700.00 1600.00)
    Generation Results
     Number of Etch Shapes                              1
     Number of Islands(non-conducting)                  1
     Shape priority                                    -1
     Number of Manual Voids                   0
     Number of pins/vias not connected        0
     Number of pins/vias partially connected  0
     Total Area of Etch Shape(s)              0.720                (sq in)
     Total Area of Boundary Shape             0.720                (sq in)
     Shape area/Boundary area(%)              100.00
     Total Area of Islands(non-conducting)    0.720                (sq in)
     Island area/Etch area(%)                 100.00
    Shape Instance Settings
    Shape fill
     Fill style                               Solid
    Clearances
     Thru pin                                 DRC                  25.00  <<<<<<<<<<<<<<<<<<<<< This is the oversized setting:
    Shape Settings (Second Shape in the design )
     Net name                                 dummy net
     Class                                    ETCH
     Subclass                                 TOP
     Extents                                  (2600.00 700.00)  (3700.00 1400.00)
    Generation Results
     Shape priority                                     0
     Total Area of Etch Shape(s)              0.770                (sq in)
     Total Area of Boundary Shape             0.770                (sq in)
     Total Area of Islands(non-conducting)    0.770                (sq in)
    Shape fill
     Fill style                               Solid
    Note no changes so this shape is following "Global Rules"
    All the best.
  • Geras
    Geras over 6 years ago in reply to excellon1
    Thanks for the reply.  Sadly this report only reports the Global void controls and leaves out the settings for the instances.  I've looked at this report many times but can't get it to report the void controls for each shape instance.
  • masamasa
    masamasa over 6 years ago
    you can get an instance report for only one shape at a time.
    you can not get a report for multiple shapes.
  • Geras
    Geras over 6 years ago in reply to masamasa
    Is it possible to do this with a SKILL script?
  • eDave
    eDave over 6 years ago in reply to Geras
    Yes, it's possible with skill. This might get you started:
    foreach(s, axlDBGetShapes("BOUNDARY"), p = axlDBGetProperties(s ->dynamicGroup), when(length(p) > 1, printf("%s: %L - %L\n", s ->layer, s ->bBox, p)))
