  3. Error with PCB Symbol Update (OrCAD 17.2)
  • Views 15778
EASiA
EASiA over 6 years ago
Hi All,
Perhaps what I am trying to do will not work but as was discussed in my other forum posts, I am translating a board from Altium to OrCAD. I have got a lot of the issues settled but for the 6 footprints that will not Netlist properly by means of not replacing because of the pin name mismatch, I tried to replace the symbol with extra pad removed and I get the following error:
'X' symbol starting to refresh:
ERROR(SPMHNI-270): 1 pins found in the symbol in the physical design, but missing from library symbol. They are:
5_1
What would be the issue here? Is the only way to replace it by means of making a new netlist and manually replacing them? I was hoping to pre replace them and then do the new netlist but this does not look like it can be done.
  • CadAce2K
    CadAce2K over 6 years ago
    Hi. Your netlist (schematic) symbol's pins do not match the PCB footprint. Check the schematic symbol vs the layout footprint. Good day.
  • EASiA
    EASiA over 6 years ago in reply to CadAce2K
    I am getting that error before running the netlist. I am trying to see if I can replace the symbol on the PCB before running the netlist option. The error above is when I have an unconnected PCB right after translating the PCB. I wanted to fix the PCB symbol before running netlist.
