  3. Error During netlist creation in Orcad Capture 17.2
  • Views 15454
ecycv71
ecycv71 over 6 years ago
I am facing below error when I tried to create netlist from my schematic.
"Unable to create the following new pin instance, SSTX2¡V, as the pin definition was not found.
Reference Designator: U29. ".
Pl help on the above.
  • CadAce2K
    CadAce2K over 6 years ago
    Hi. It appears there's an issue with how you defined the pin in your library part (or cache part). Go into the symbol and look at each pin, and see if that pin is different from the others. Also, was the symbol changed (on the fly), and possibly U29 wasn't updated with the symbol change?
  • ecycv71
    ecycv71 over 5 years ago in reply to CadAce2K
    Thanks for your reply. I think issue is due to the compatibility between version from which the symbol is imported. It is resolved after I created a new symbol.
