  3. Library Builder 17.2 import a pad created in the pad ed...
  • Subscribers 163
  • Views 14326
Library Builder 17.2 import a pad created in the pad editor
t1mk
t1mk over 6 years ago
I need to replace a rectangular pad created in LB with a chamfered rectangular pad created in the pad editor to indicate pin 1.
Is there a way to do this?  Or is there a way to do this directly in LB?
  • RFinley
    RFinley over 6 years ago
    • Create a variant padstack of the existing rectangular pad.
    • Make the chamfer edits to the variant padstack.
    • Save.
    • Then, map the variant padstack only to pin1.
    (I have Orcad Library Builder, which should be the same product)
