  3. BGA Local Fiducials
  • Subscribers 163
  • Views 15414
BGA Local Fiducials
jatins
jatins over 6 years ago
Hi
I was wondering at what point does it become necessary to add local fiducials to the BGA packages.
Would a 0.8mm pitch package be placed correctly by machine if i do not use local fiducials or what if i go for 0.65/0.5mm pitch?
Would small packages with 24/48 pins don't require them as much as 324 pin packages?
  • RFinley
    RFinley over 6 years ago +1
    Fiducials are only used if the machine is programmed to look for them during the alignment process every time a bare board is loaded. If you have tons of extra room, why not? Esp for 324 pins. We put…
  • RFinley
    We put two fiducials towards opposite corners on every board and 01005's yield ok.  But, our boards range from the size of a grape to a playing card.
    To avoid going back and adding them, get ahead of any copper image-shift problems and locate a single fiducial in two areas on the board where extra accuracy will pay off in yield.
    Talk to your assembly house if you're designing a rigid-flex assembly.  These have to be baked in an oven before assembly to drive moisture out as humidity causes flex expansion like crazy.
