  3. Enabling High-Speed Option settings?
  • Views 12838
ameehan2
ameehan2 over 5 years ago
I'm working on a layout concurrently with a remote designer - both using high-speed/miniaturization licenses. I keep seeing prop delay DRC's in the section he's working in, but he says there are none and I must not have the high-speed option enabled. I always use the high-speed license, and have the electrical constraint modes all checked 'On', so not sure why we're seeing different things. Any clues?
Thanks very much for any advice you can provide.
  • RFinley
    RFinley over 5 years ago
    Since you see prop delay DRCs, looks like your license is working correctly.  Allegro skips DRC checks that aren't licensed even if the constraints are entered.
