  3. 172. 062 hotfix - using wildcard in library search not ...
  • Subscribers 163
  • Views 1622
172. 062 hotfix - using wildcard in library search not working
avant
avant over 6 years ago
While in footprint edit mode, I cannot search for footprints using wildcards such as cap*.dra, *0402*.dra, etc.
It does not work in edit board mode either.
I'm running Windows 10 pro.
Wildcards still work in Allegro version 16.6.
I have no clue what is going on. Looking for suggestions to fix.
  • avant
    <solved>
    go to user settings and select ui/browse/new_filedialog_disable
  • Adrian Hobbs
    Adrian Hobbs over 6 years ago in reply to avant
    I've also had to use this variable to stop some dialogue boxes (File>Open) from opening so wide that they go off of the screen. Question is .. when should we expect to remove this variable so that we get the 'new file dialog' ?
