  3. SigNoise Error/Warning
  • Subscribers 166
  • Views 2042
nhviraj
nhviraj over 5 years ago
I am using allegro 17.2 the problem I am facing is when I route the differential pair,
"SigNoise Error/Warning"  window appears and hangs the entire system searching for some file, and ends up with this:
E- Field solution failed for STL_1S_1R_9187
E- Field solution failed for STL_1S_1R_9188
E- Field solution failed for STL_1S_1R_9189
E- Field solution failed for STL_1S_1R_9190
E- Field solution failed for STL_1S_1R_9191
E- Field solution failed for STL_1S_1R_9192
E- Field solution failed for STL_1S_1R_9193
E- Field solution failed for STL_1S_1R_9194
E- Field solution failed for STL_1S_1R_9195
E- Field solution failed for STL_1S_1R_9196
E- Field solution failed for STL_1S_1R_9197
E- Field solution failed for STL_1S_1R_9198
E- Field solution failed for STL_1S_1R_9199
E- Field solution failed for STL_1S_1R_9200
E- Field solution failed for STL_1S_1R_9201
E- Field solution failed for STL_1S_1R_9202
E- Field solution failed for STL_1S_1R_9203
E- Field solution failed for STL_1S_1R_9204
E- Field solution failed for STL_1S_1R_9205
E- Field solution failed for STL_1S_1R_9206
E- Field solution failed for STL_1S_1R_9207
E- Field solution failed for STL_1S_1R_9208
E- Field solution failed for STL_1S_1R_9209
E- Field solution failed for STL_1S_1R_9210
E- Field solution failed for STL_1S_1R_9211
E- Field solution failed for STL_1S_1R_9212
E- Field solution failed for STL_1S_1R_9213
E- Field solution failed for STL_1S_1R_9214
E- Field solution failed for STL_1S_1R_9215
E- Field solution failed for STL_1S_1R_9216
E- Field solution failed for STL_1S_1R_9217
E- Field solution failed for STL_1S_1R_9218
E- Field solution failed for STL_1S_1R_9219
E- Field solution failed for STL_1S_1R_9220
E- Field solution failed for STL_1S_1R_9221
E- Field solution failed for STL_1S_1R_9222
E- Field solution failed for STL_1S_1R_9223
E- Field solution failed for STL_1S_1R_9224
E- Field solution failed for STL_1S_1R_9225
E- Field solution failed for STL_1S_1R_9226
E- Field solution failed for STL_1S_1R_9227
E- Field solution failed for STL_1S_1R_9228
E- Field solution failed for STL_1S_1R_9229
E- Field solution failed for STL_1S_1R_9230
E- Field solution failed for STL_1S_1R_9231
E- Field solution failed for STL_1S_1R_9232
E- Field solution failed for STL_1S_1R_9233
E- Field solution failed for STL_1S_1R_9234
E- Field solution failed for STL_1S_1R_9235
E- Field solution failed for STL_1S_1R_9236
E- Field solution failed for STL_1S_1R_9237
E- Field solution failed for STL_1S_1R_9238
E- Field solution failed for STL_1S_1R_9239
E- Field solution failed for STL_1S_1R_9240
E- Field solution failed for STL_1S_1R_9241
E- Field solution failed for STL_1S_1R_9242
E- Field solution failed for STL_1S_1R_9243
E- Field solution failed for STL_1S_1R_9244
E- Field solution failed for STL_1S_1R_9245
Command > `EscEsc
    This got flagged as spam (to answer your question when this was moderated) because the repeated text is one of the indications used to detect spam. Anyway, it clearly wasn't so I approved it - hopefully somebody in this forum can help you out.
