  3. Multi component cross-probing HDL->PCB
  • Subscribers 163
  • Views 1159
nic92
nic92 over 6 years ago
HI,
is it possible to use box / rectangle select in HDL to crossprobe and select multi components in PCB Designer at once?
I can ctrl+left click multi components one at a time in HDL and than use move command in PCB Editor but I can't box select.
If I set the filter in HDL to only symbol, box select and then use highlight in HDL, I see in the PCB Designer console output that the parts are first selected and then highlight, so the functionality to cross select multiple components at once exists.
Nicolas
