  3. OrCAD Capture V17.2 - BOM configuration management
  • Subscribers 167
  • Views 3200
Eliottt
Eliottt over 5 years ago
I have to manage two board with the same schematic but different BOM.
The two DSN have the same property "NM" for non mounted component, only this column is different on the two designs.
The board is exactly the same, only DSN/BOM are different.
I want to know if there is a way to easily manage this double configuration.
After merging the two schematic, today I proceed this way;
1) I added a "NM_C2" column in the property
2) After I updated the schematic I need to export the BOM twice with "NM" and "NM_C2" configuration.
3) The schematic is not clear because only the property "NM" is displayed, it's not easy to check the "NM_C2" configuration.
Why In the property editor we can't change the display configuration for all components ? Today we need to change the display property one component by one component from the schematic editor ...
Thank you for help.
Eliott T.
  • RFinley
    RFinley over 5 years ago
    The CIS Variant feature in Part Manager is your friend.   Especially with "Variant View" that can highlight affected parts (might want to change the gray color to something more visible.)
    CIS allows you to assign and remove parts from CIS Groups while editing the schematic (you won't have to keep part manager open all the time.)
    We use groups to manage and verify NoLoad vs. placed parts.  When changing the status, add the part to the load group but remember to take it out of the previous group first or you get an ambiguous error (one entry says load it, other entry conflicts.)
  • CadAce2K
    CadAce2K over 5 years ago
    "non mounted"? Don't you mean DNI? Add the property NOTE and add DNI for your non-mounted components. Variant works pretty well for this activity.
  • djs42
    djs42 over 5 years ago
    As others point out CIS Variants work best here. If you don't have CIS you could add a properties to each part in your schematic, say 'NM1' and 'NM2', and enter values for each variant of your design. Include these 2 properties in the Capture BOM string.
