  3. DRC error: Mechanical Drill Hole to Pin spacing
  • Subscribers 166
  • Views 17505
jatins
jatins over 5 years ago
Hi
I have mechanical drill holes next to SMD pins in my footprint and i am getting DRC error:
Constraint Value: 0.2032mm
Actual Value: 0.1352mm
I have changed all the values in constraint manaager to 0.127mm but still getting this error.
  • jdavison
    jdavison over 5 years ago
    Have you checked the constraint modes under mechanical spacing? That is the default value. Turn them off.
  • jatins
    jatins over 5 years ago in reply to jdavison
    Do you mean under Constraint Manager>Spacing
  • jdavison
    jdavison over 5 years ago in reply to jatins
    Hi
    Go to set up -  constraint - modes -
    in the analysis setting click on design. You will see mechanical spacing. Click on this and turn off this function.
